Интеграция с Spektrum
Revision as of 15:26, 15 October 2018 by Gstatopen (Talk | contribs) (Created page with "с прошитым новым загрузчиком - см. Решение проблем")
С версии 2.4.3 Spirit, вы можете использовать интеграцию со Spektrum!
Это значит, что вы можете полностью настраивать Spirit с помощью передатчиков Spektrum в реальном времени без использования компьютера.
1 Требования
Чтобы интеграция начала работать, потребуется:
  • Передатчик Spektrum: DX6e, DX6 Gen 2, DX6 Gen 3, DX7 Gen 2, DX8 Gen 2, DX9, DX10T, DX18 Gen 1, DX18 Gen 2, DX18T, DX18QQ, DX20 or IX12
  • Телеметрийный приемник SPM4649T
  • Кабель интеграции Jeti (доступен в нашем магазине или можно сделать самостоятельно).
  • Spirit firmware: 2.4.3 (с прошитым новым загрузчиком - см. Решение проблем)
2 Wiring
2.1 SPM4649T receiver
The receiver is able to transfer everything including channel data and telemetry. This mean that you will not need to connect anything else except this.
Info.png In case that your SPM4649T receiver is not bound yet, you can do so by a Bind plug. Connect the Bind plug to the servo socket. Then power up the receiver (you can use BEC power supply and/or free port in the unit such as CH0 or AUX2). Optional satellites can be binded normally as described in the Manual.
Info.png In case that the ESC telemetry is used, the primary satellite can't be connected. For the Castle Creations and Kontronik Kosmik/Jive Pro ESC telemetry primary satellite can be still used.
3 Transmitter preparation
3.1 Firmware update
  • DX6e does not need update (version 1.00 will work).
3.2 Configuration
Configure:
  • 1: ESC
  • 2: Text Gen
  • 3: Flight Pack mAh
5 Integration Menu
5.1 Entering the menu
5.2 Closing the menu
5.3 Navigation
Info.png To navigate in the menu you can use Aileron and Elevator sticks.
  • Aileron Left - Back in the menu; Stop edit of a parameter' value.
  • Aileron Right - Enter a Submenu; Edit selected parameter.
  • Elevator Up - Go up in the menu or submenu; Increase value of selected parameter.
  • Elevator Down - Go down in the menu or submenu; Decrease value of selected parameter.
6 Telemetry data
6.1 Displaying the data
  • BEC [C] - ESC Telemetry | Main Battery consumed capacity (1234mAh = 123.4C)
7 Troubleshooting
