Вывод оборотов с CC Phoenix Edge.
Revision as of 09:29, 16 October 2018 by Gstatopen (Talk | contribs) (Created page with "Необходимая переделка")
Регуляторы Castle Creations Phoenix имеют вывод со встроенного датчика оборотов. Остается только подключить этот провод и отключить встроенный гувернер.
1 Необходимая переделка
For usage with the Spirit units a small modification of the RPM cable is needed.
- Move the White cable to the middle in the Servo connector.
- You can do so with a needle easily.
- Wire layout
- White wire: RPM Output Signal (PIT pin)
- Yellow wire: Throttle signal (AUX1 port)
- Red wire: BEC Voltage (AUX1 port)
- Brown wire: Ground (AUX1 port)
2 Changing ESC settings
It is very important to change ESC mode so that internal Governor is disabled. This can be done by Castle Link software.
3 Governor Settings
- Throttle Frequency: 60Hz.
